Masterchief87
Android Expert
Hello all, I've put together a flashable stock ROM for the T-Mobile Avant. This could be useful if you messed something up and dont have a nandroid backup and you don't feel like having to reflash the whole firmware with Odin and then reinstall TWRP or CWM.
This is not a flashable update.If your phone hasn't already been updated to G386TUVU1ANK3 then WiFi won't work on this ROM.
THIS ROM IS 100% FACTORY STOCK FOR T-MOBILE ONLY AND IS NOT PRE-ROOTED.
FLASHING THIS ROM OVER TOP OF THE METROPCS FIRMWARE WILL CAUSE WIFI TO QUIT WORKING.
I didn't include root because pre-rooting the rom will also keep WiFi from working and it is very easy to flash SuperSU after flashing the ROM.
It is important to turn the phone back on and let it sit for a few minutes before doing your setup. If you are going to root It is necessary to let the phone boot up at least once and sit for a few minutes before rebooting back into recovery to flash SuperSU and then doing your setup after rooting.
I am not responsible for thermonuclear war, the death of your pet, or anything that may happen to your phone. You are choosing to flash this at your own risk. I have tested this ROM thoroughly and have not had any problems with it.
Instructions:
[1] Factory reset
[2] Flash ROM
[3] Reboot phone
[4] Let it sit for a few minutes
[5] Flash SuperSU for root
[6] Set up your accounts and apps
ROM Download: http://www.mediafire.com/download/h0861b4022pzmvb/T-Mobile_G386TUVU1ANK3_stock.zip
SuperSU flashable zip
Download: http://download.chainfire.eu/supersu
Instructions:
[1] Factory reset
[2] Flash ROM
[3] Reboot phone
