Root [T-Mobile] help, chelpus and lucky patcher
Heffler
i have a s4 running wicked 9.1, i am trying to find the latest version of chelpus google play mod, and lucky patcher....i read that some games need the google mod and some need lucky patcher...now i know that chelpus makes both...and i know lucky patcher can patch the google play app....but never had much luck patching it...does he have a website? or links to latest releases...and which is better? which to install first?
Ok what do you mean by this. If it's warez then you sir are on the wrong place.
Ok warez is obtaining paid apps for free. But if your looking for the chulpus app or the lucky patcher app then I can help you
Chulpus app
Google Play Store 4.1.6 (Modded by ChelpuS) APK Free Download
And
Lucky patcher
http:// lucky - patcher. netbew. com/
why thank you kind sir. i was not asking for warez...i know exactly where to find them... i was just confused about the diff between lucky patcher and google play mod....cause they seem to do the same thing....
Well the market thing completely modifies the market. While lucky patcher gives you control over all apps.
OK...HAVING SOME ISSUES...as i stated..i am running wicked rom 9.1....but i cant install the chelpus google play mod....i dont know why....i have tried a couple versions before the one u gave me and all with same results.....getting frustrated...i have the option checked to install 3rd party apps too....wtf is going on...
I don't know what to tell you dude.
