Root [T-Mobile] I'm currently rooted on 4.4.3
MaRz0o
Member
I'm currently rooted on 4.4.3 and I keep getting the pop up urging me to rotate on my Moto X. If I update would that remove my root?
What carrier are you with, so I can move this to it's own thread in the rooted section.
T-Mobile. But I purchased the phone unlocked.
I was in the same situation. Don't do it.
I had my T-Mobile unlocked Moto X rooted with the TeamWin recovery, and when I tried to accept the OTA update, it booted into recovery, and then I got a boot loop. Every time it tried to reboot to install the update, it got stuck in the TeamWin recovery. Then if I tried to boot from there to a normal boot, the phone would reboot itself and then go back into TeamWin recovery.
I had to download the entire factory image package (huge and from a slow server, so the download took hours) just to get the stock recovery back to flash using moto-fastboot.
If you want the OTA update, flash the stock recovery back first, and then accept the update.
Moved here on it's own, so you can get the proper support.
