Aboot ver B (Jun 2013)/TWRP Touch Recovery
TWRP for the T-Mobile / MetroPCS LG Optimus F3
If you are on Virgin Mobile / Sprint, go here.
TWRP = Team Win Recovery Project
Source: TeamWin - Home | TeamWin
Visit: TeamWin Projects - TWRP 2.8 - | TeamWin for details
What doesn't work:
Data Partition restore has been fixed by gherkaul
Thank you
First time you boot into the TWRP Recovery, it may take upwards of a minute to initialize.
To Install:
DOWNLOAD:
Version 1
sha1sum: 6c67897716ac4ff2220f09dd105e9c8b92daa4b6 twrp-install-v1.zip
I'm not good at writing batch scripts, but the Windows one should work. The Linux/OS X installer is of a much better quality than the Windows version. Follow the readme file that's included.
To get into TWRP:
7/9/2015 - Initial release
- TWRP Version 2.8.0.0
- Works with T-Mobile Optimus F3
What doesn't work:
- Haptic Feedback
- You tell me?
Thank you
To Install:
- Your phone needs to be rooted
- You need to enable USB debugging in Settings > Developer options
- Run aboot-install.bat (or aboot-install.sh on Linux/OS X)
- Run install.bat (or install.sh on Linux/OS X)
DOWNLOAD:
Version 1
To get into TWRP:
- Run reboot-recovery.bat or reboot-recovery.sh (if you're on Linux/OS X)
- Or, run `reboot recovery` as root on your device
