the nexus one is the google experience phone. It's bare. No carrier crap or bloatware.
free hotspot![]()
so as I am on sasktel which is wcdma (hspda+) an unlocked t mobile nexus one should have no problems working on data, phoning and text messaging right?
if WCDMA is GSM then yes, but you'll want to check the frequencies to make sure you can get 3G.
There's an AT&T and T-Mobile version of the nexus one and they run different frequencies.
check what you're carrier uses and match that to the right phone![]()
So as my carrier runs 1900 and 850 I need a AT&T Nexus One?
yup
good luck finding one. I hear they're relatively rare. I have one, but i'm hanging on to mine![]()
I can't tell... and it doesn't look like they know either.
I'd ask until you get a satisfactory answer, b/c there are definitely 2 versions.
good luck!
The cellular band that is listed is for AT&T: WCDMA (UMTS) / GSM 850/900/1800/1900
