revins95
Member
Hello all. I have the newer T-Mobile GS3 SGH-T999L with baseband T999LUVAMB7 and build# JZ054K.T999LUVAMB7. From my understanding this is somewhat different from the original T-Mobile version as this has true 4g radios in it as to where the first one has radios for HSPA+. Well i found out the current CM/AOSP/AOKP ROMS don't work because of the difference in the baseband and build#.
What i was directed to do was to unzip the rom and in notepad, erase all the assert lines. so far this has done nothing as I don't know from 'where' to 'where' i am to erase.
Flashing them as is does nothing and i love these custom ROMS and want to try the newer versions od android other than 4.1.2. any help is appreciated. if you know of other methods that will help as well
