Root [T-Mobile] Samsung Galaxy SII(Boost Mobile) transfer to Samsung Galaxy Note II (T-Mobile)
traciefly
I currently have a Samsung Galaxy SII(Boost Mobile) and I want to know how I can transfer my apps that I paid for to Samsung Galaxy Note II (T-Mobile). I was told by the T-mobile rep that when I log in my gmail account my apps will automatically appear but that didn't happen. I don't care about the free apps just the ones I paid for. :mad: Can anyone help with this? :confused: Is it possible?
Just in case you need a more detailed explanation...
On the new device make sure you use the same gmail address as the old device
Login to the Play Store with the gmail address
Press the menu button
Select My apps
Select All at the top
It should then show every app you ever downloaded with that gmail account
even the ones you had previously uninstalled.
Select the app you want on the new device and click on install
