Root [T-Mobile] SuperSU binary not installed
Mandroid7
I'm having serious problems with my GS4. I tried to root it with TWRP. I was able to do all the steps and it finally said that it was successful. The problem is that, Root checker said that I was not rooted yet. When I installed SU, it told me the that binary was not installed. Therefore, I can't update a binary that does even exist. Thanks in advance for your help!
How exactly did you root with TWRP? (TWRP is a custom recovery - I don't believe it will root anything for you).
What steps did you follow to root?
TWRP is just the recovery that is helping you flash the updates/changes to your phone. Thanks for the link - the sequence of steps looks right - but need to make sure you flashed the right files.
What model S4 do you have? (specific to which carrier and what firmware version does it have now)
I did everything, exactly as instructed in the tutorial that you suggested. The problem that I have, and forgot to mention, is that I get this screen before I enter the TWRP custom recovery screen. What should I do??
What is "Recovery is not Seandroid enforcing?
