T Mobile (UK) voicemail charge workaround?
Heroine
Member
Hi, Does anyone know of a workaround to avoid TMobile (UK) voicemail charges? Someone suggested I set my own number to dial and collect voicemail and it would be free....but it still charges me :(
Just wondering if other Tmobile UK users had found a way to avoid the charges? :D
Switch to another network that doesn't charge for voicemail (so, that's any apart from t-mobile I think).
Or use something like hullomail for your voicemail, you can then call a geographical number to retrieve your voicemail or use their android visual voicemail client or listen to them in your email.
Sadly, not an option since I have just started an 18month contract.
Thanks Paul, wasn't aware of that option...just googled hullomail and will give that a try...tnx a lot :)
