Root [T-Mobile] USB Debugging/Developer Options Galaxy Note 3
L34k3d
If you didn't know you can enable the developer options in the settings menu. By going into settings then into about phone. Tap the build number 7 times and it unlocks it in the settings menu. From there you can enable usb debugging.
