Have an issue I believe with the T989 battery temperature sensor or thermocouple (T/C). The symptom is that after I plug in the charging cable in about 5 to 6 sec I get a warning message that the battery is too hot and charging is stopped.
I know the battery is at room temp and I have used 5 batteries all with the same result. I know the micro-USB port is OK because I can run Kies on the port and transfer gigs of data with no issues.
The T/C is a little cylinder on mobo near SD card slot I have been told. I have cleaned out the T/C with alcohol and compressed air several times to no avail.
Can I replace the T/C without replacing the entire mobo? Can I turn off the temperature sensing sw so this warning and charging shutdown does not occur?
If I can do either if these things as much detail as possible to howto would be much appreciate.
I work in the battery business so I am not concerned with safety issues as I will self monitor the charging. I can charge the battery out of the T989 but need to solve this issue so I can charge the battery in the T989.
tia
tia
