I meant prior to the problem did you drain down the battery to zero or near zero? Maybe try trickle charging the battery via USB/PC to get a small charge back to the battery. Then, if it shows even a nominal charge switch back to AC.
Also, you don't mention the history, age, or any other possibly relevant details.
