Apps TableLayout declared in XML, not found in code.
Ojive
Heya!
This has started to do my head in, and I can't figure this out.
After many searches on google, i found several examples of how to programmatically/dynamically add rows to a TableLayout.
My customers.xml file.
Code:
<?xml version="1.0" encoding="utf-8"?>
<TableLayout xmlns:android="http://schemas.android.com/apk/res/android"
                android:layout_width="fill_parent"
                android:layout_height="fill_parent"
                android:stretchColumns="0,1"
                android:id="@+id/customers_table" >
</TableLayout>
My CustomersActivity.java:
Code:
setContentView(R.layout.customers);
later on:
TableLayout tl = (TableLayout)findViewById(R.id.customers_table);
My AndroidManifest.xml
Code:
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
    package="com.crmdeskapp"
    android:versionCode="1"
    android:versionName="1.0" >
    <uses-sdk android:minSdkVersion="10" />
    <application
        android:icon="@drawable/ic_tab_support"
        android:label="@string/app_name" >
        <activity android:name=".CustomersActivity" android:label="@string/app_name"
          android:theme="@android:style/Theme.NoTitleBar"
          android:screenOrientation="landscape">
          <intent-filter>
            <action android:name="android.intent.action.MAIN" />
            <category android:name="android.intent.category.LAUNCHER" />
          </intent-filter>
    	</activity>
    	<activity android:name =".CustomerActivity">
    	</activity>
    </application>
    <uses-permission android:name="android.permission.INTERNET"></uses-permission>
</manifest>
Now, for some weird reason "findViewById" returns null. This is frustrating as hell since "customers_table" TableLayout is declared RIGHT THERE.
Am i missing something? Newbie here.
Where do you call setContentView(R.layout.customers)?
You should make sure to call it in the acitivity's onCreate() method.
Right. I think i found the source of my problem. Orientation.
I started experimenting with orientations, and layouts for these. Apparently, the "customers.xml" had to be identical (or the name of the layout atleast, had to be identical). Problem solved.
.....i think :D It runs atleast.
