Help Tablet battery issue
Jason34
So a couple days ago my daughters Samsung tab tablet has had problems with the battery %. If I charge it to 100% it drops to 90 then 70 and so on to 1% then holds there in a matter of about 5 min. After that it maintains the 1% for 5 to 7 hours. I have searched alot on this, done bump charge, factory reset and recalibrate the battery. Normaly it wouldent be a issue sense it's full life is there but it going below 5% causes the tablet to go into a battery saver mode and cuts cpu usage and screen brightness and no way to adjust it back when it drops that low any help would be appreciated!
Also it started happening when I had to open the case because the power button and volume controls stoped working to find the power controls came unplugged from the circuit board. Maybe I hit something I shouldn't have.
If you didn't wreck your tablet from tinkering with it, Check your device and see if there was an update available for it. I encountered an issue like that with my Samsung Galaxy 10 and later found out that I had missed an update for it. After I installed the update, all went back to normal. But if your device is a few year old it may be time for a new battery depending on the amount of usage was made with the device.
