Tablet will not charge}
  • Start date Start date
A
Android Question
Guest
my Tablet will not charge. It is one week old. I am traveling and have used approved voltage converter and it charged alright.
Now it will not charge even from a usb port.
Any suggestions?
Would be big help
Thanks,
Rob
Bad battery, bad charging circuit in tablet, bad microUSB port, bad cable. Suggestion? Figure out (or pay someone to figure out) which one is the problem. You can't fix something if you don't know what needs fixing and "doesn't charge" is a symptom of a problem, it's not the problem itself.
