Apps Tableview or Listview
Hi all,
I'm building an app which gets a ksoap reponse back from a web service that I then need to display in a table of some kind which can then have selectable rows.
Each row would need to be broken out into a number of columns. Should this be achieved using a tableview or a listview ideally?
You can use which view that you feel most comfortable with.. Some developers like Listview some do like Tableview.. Myself i like to use RelativeLayout for my apps.. Its all about how you like to work.
Thanks CompBoy. I've created a TableView which is built by looping through my ksoap web service response and programatically creates the rows in Java. I can add an event listener so that if I click on a row it changes the background color, however is there any way to assign the individual cell values from the selected row to variables when it is clicked?
As essentially I need to select a row and then be able to click a button so that the values from the selected row are passed over to a new intent.
Hope that makes sense!?
