That's your NFC. Some carriers its built into the battery; others it's in the battery door.There are some metal tabs on the inside of the back of the battery cover that touch 2 tabs next to the sim card. I thought maybe it was for the s-beam but my buddies don't have it on the S3's. What are these for?
Yeah the Note 2 has NFC on the back cover and the S3 has it built into the battery. I really wish they would have done that for the N2!
On Samsung's site you have to select your carrier when making a battery purchase so that you get the correct battery.
Some Notes, NFC is in the battery door; others it's built into the battery.What is the difference in the batteries?
I thought all of the Note 2's had NFC on the battery door?
