Help task killer and apps closing after opening
BabelFish
So when I got my phone, apps would sometime right after I opened them. I assumed this was because I didn't have enough memory. I downloaded task killer to help with the problem. Whbenever aan app would not open, I would close everything with task killer and the app would open with no problem.
I have read a lot of articles/threads that state that task killers are not necessary, so I removed it. The problem is that my problem returned. Why do apps close right after they are opened (not a force close or some other error) . How do I fix the problem without task killer?
What you want to do is disable useless BS services at boot and shutdown if restarted. Normally closing app's are not required unless you know what you are doing regardless of what the tool handguide says. So go download something like Start Auditor which you can manage with what runs and what is disabled, BTW don't disable everything only disable what you don't use.
:O well maybe I wasn't clear. Now if you disable services from starting it obviously won't be allocated and some does restart so use what I told you it will close them if restarted. It's not really hard just select disable on the service and its done, very simple.
I checked the running services section in android and there are not a lot running. Is that was is causing apps to 'fail' to open, lack of resources or is it something else? If it is lack of resources, doesn't that present an argument for having task killer? Just curious
