Task Manager-How to I delete it?
Are you talking about the task manager that came already installed in the phone? If so you can't without rooting or jail breaking your phone.
Hello and welcome to Android Forums! :)
The others are correct. If the task manager in question was already installed when you bought your phone, you'll have to root it to remove it. Let me offer a word of caution. Many apps provide services for other parts of the OS and if you remove them, you can disable certain features or make your phone unusable. More importantly, system apps are not easily restorable like simply installing an .apk file. And once deleted, even a factory reset will not recover them. You will have to locate and flash a stock rom image to get them back. If you plan on rooting and deleting those apps, please check back here first before you do anything so we can make sure it's safe for you to delete those without any negative impact to your phone.
I want to delete task killer but the problem is it's not installed on the device! But What'sapp sent me an alert that I should delete it. So I've searched for it but can't find anything. So help, please!
If it's not listed in your apps, then I wouldn't worry about it. It's not installed.
