I was wondering if it is possible to get tasker to set the audio or voice of the other person on a call to come through the headphone jack but keep the mic or the phone working. When the phone is in docked in the car cradle?
I've been doing a bit of looking and reading and I'm afraid I'm not able to find any solutions to do exactly what you want - that is, to split the audio routing so that sound is played through the headphone jack but the device's built-in microphone is used for recording (did I get that right?). The closest I've found so far is the AutoVoice plugin, which I believe does let you override the audio routing (for instance, to force notifications to play over the device's speakers instead of the audio output), but I don't think it will let you split the streams.
Maybe it can get you pointed in the right direction though - good luck!
Thanks for the update, i have also checked out Sound about and i can get it to work but i can't get it to automate using tasker or anything else. I have also posted in their forum but it's exactly active.
