Tasker - Bluetooth
MsL
I know that there must be a way but I can't figure it out. I would like that when I turn on my bluetooth headset my bluetooth will connect to my phone and then when I turn off my headset the bluetooth connect would turn off.
I hope that makes sense!
Which was why I dumped this product when I had it. I tried to set my bluetooth devices. I started using SVC+ and it is far easier to use with bluetooth devices.
Find Tasker in the the Play Store. It's what I use. The problem is you have to setup a specific time for blue tooth to turn on. The phone can't just turn on BT just because your headset is on. However, you can set it up to where BT turns off on you phone whenever you disconnect from the device you're paired to. I hope this helps.
I agree with TJ225---Smart Volume Control+ is a really good app. Don't like Tasker or Audio Manager---they never perform as promised.
I know that there must be a way but I can't figure it out. I would like that when I turn on my bluetooth headset my bluetooth will connect to my phone and then when I turn off my headset the bluetooth connect would turn off. ....
Personally I always leave BT turned on (on the phone) as I've never found it to be a battery hog (at least, with my usage, which is actually fairly minimal). That way when I turn on my headset it connects automatically.
Dave
