Tasker Calendar Won't Delete
Betacord360
I had downloaded Tasker and ended up not using it. The app has been deleted for several months, yet the synced Tasker calendar still remains on my calendar list. I'm unable to find a way to remove it from my device. Any helpful suggestions are much appreciated.
what calendar are you using? if you go into the calendar settings, there should be a list of apps or accounts that you can uncheck. i have this on my google calendar as well as samsung's calendar.
I use Google Calendar, and I can find Tasker in the settings, but there aren't any options to remove or hide it. See screenshots.
have you tried wiping cache for the calendar? you can wipe data as well. but then you just need to make sure that your events or alarms have been backed up to google or whatever account you want the calendar to be in....cuz wiping data will erase all data from your calendar.
