mystvearn
I did a tasker mode to turn on flight mode when I sleep at night. I followed this link: Airplane Mode at Night - Tasker Wiki
Tasker is set to run between 1am-6am.
I also turn on alarm clock plus desk clock and charge the phone during sleep. When I turn on the clock, and then tasker flight mode kicks in, it goes away from the dock mode into the sgs2 menu to enable the flight mode. Only problem is that it does not go back to the dock screen and I have to manually press the back button.
When I wake up in the morning, tasker does disable the flight mode without going into the phone settings. Is there a way to make tasker enable flight mode in the background when alarm clock plus is running? The task works fine to disable the flight mode, but not enable it.
I need to on alarm clock plus mode first because I use the accuweather built in widget to get weather and that needs data connection for the weather to be first displayed. When I wake up, the alarm will tell me the time and what is the weather.
