Tasker has no built-in variable for the proximity sensor
LouBall
There is Proximity Sensor in State profile menu, but no variable to monitor it.
At least it is not in the list of built-in variables in the User guide.
Couldn't you create a profile based on the state of the proximity sensor and have it launch a task that sets a variable for you to monitor? I know it's a bit of a workaround, but it seems like it should be fairly easy to do.
