Tasker Icon
ChadWilliam1
I have three Tasker widgets/actions on my home screen. They are one click volume adjustments, Silence, vibrate and loud. I would like to change the icons to something from an icon pack but when I click on the icon inside tasker I can only seem to get to taskers icon or app icons... I can not seem to access one of my icon packs.
Any suggestions?
Thanks
If it matters it is an HTC 10, running venom rom 1.40 unlcocked boot and s-off.
I use Tasker App Factory with Tasker.
There are a number of places in Tasker where icons can be set.
I have never been able to select an icon from ...
Contact Photo
Contact Media
Download More Icons​
I have accessed images from ...
Application Icon
Built-In Icon
Local Media​
I use Built-In Icon and Local Media.
... Thom
Welcome to Android Forums.
It has never worked for me.
Are you accessing an icon from an icon pack in Tasker? If you are ... which Tasker interface and which icon pack? Icons can be selected at...
Profile
Task
Widget
... Thom
OK I got this figured out.
If you pick task shortcut instead of task 1×1 you can then edit the icon by holding it and then editing the icon.
Here is what I have now. So I can just tap one to adjust all the volumes.
Thanks guys
I was assuming you wanted it transferable to other devices.
The technique you specified works on my Turbo 2 running Nova Launcher Prime and does not work on my Turbo 2 using the default launcher.
If I assign the icon inside Tasker from the sources I identified then it is incorporated into the package and is transferable. This is the part that does not support icons from an icon pack.
... Thom
