Tasker + Redirect Pro automation
filflops
I purchased Redirect File Organizer Pro (file/directory redirector) and I managed to set up file redirecting from my SD to my extSD, namely
redirecting
/storage/emulated/0/Pictures/iFunny
to
/mnt/extSDCard/iFunny
After setting up the two folders, the app claims to manage the folder contents and move them over automatically as the folder on the SD card gets filled, but the process does not happen in real-time, as I have to use the app widget to run all redirects when I want it to move the contents.
Tasker can launch 'plugins'(widgets), and in the list of plugins I found the widget that does this for me.
My question: How do I set up Tasker to run the widget every time I save a Picture from iFunny? The idea of variables in Tasker is still new to me and I know many people are familiar with it.
Any ideas?
You can set it up to run the save plugin every time you leave the app ifunny...
Context....app...ifunny
Enter task: stop (does nothing)
Exit task: the plugin
