Tasker Sleep mode help
Hi,
I was looking for an app that will silence the phone during the night except for specific phone numbers. Bedtime did not seem to do the trick so I downloaded Tasker which claimed it could do this
I downloaded and imported the Sleep mode from this site Auto Sleep Mode (with exceptions) - Tasker Wiki
Everything looks fine but it does not work
running DROID-X on Gingerbread
It's a fairly simple set of profiles that look like they should work. My first thought with anything that modifies the ringtone or volume during an incoming call is that I've seen reports of this not working on specific phone models. This was probably 6 or more months ago, and may not be an issue now, but it might be worth checking in the Tasker Forums to see if there are any issues with your specific phone model.
If you haven't edited anything in the profile other than the phone numbers that you want to "ring through", double check the phone numbers and check out the documentation on matching. Also note, that when matching phone numbers, there should be no delimiters in the numbers themselves (i.e. use 1234567890, not 123-456-7890), but you can also list contact names instead of numbers to make it more readable.
