Hey everyone,
For some reason I'm having problem with using Tasker on my Huawei Ascend P6 running Android 4.2.2.
I had set up a simple profile that would enable wifi, enable data, turn on auto sync, .. every X minutes. After trying this out it became clear that after a certain period Tasker would simply stop running this profile.
For testing purposes I have:
PS: I must say that I'm having the same issue with all other battery saving applications too (Juice Defender, GreenPower, Deep Sleep Battery Saver). They work perfectly until after a certain time they stop firing their events to enable the connection in the background.
Any help would be really appreciated. How can I trace this problem?
- Double checked that there are no task killers installed
- Created a profile of type "Time" that will Vibrate for 1 second from 07:00 every 2m Till 22:30
- Enabled the "log to sdcard" functionality
