Tasker Variables global
cdikland
Are variable defined by a task within one profile available to tasks within an other profile. In other words, are variable defined by tasks considered GLOBAL?? If so, then I dont understand why I cant get my If/endif block to work.
Here is what I got
Profile1 - Headphone plugged in run musicplayer, set var1=True, (Exit task) Headphone unplugged Go Home, set var1=False.
This works without fail however when I try to make use of var1 within an Exit Task of another profile such as
Profile 2 Exit task:
tsk1 -If var1=False
tsk2 do something
tsk3 endif
tsk 2 never executes even though I confirmed that var1 is set to False.
Any ideas??
Try changing your variable name from var1 to Var1 to change it from local to global variable.
Tasker for Android
Code:
Global vs Local Variables
All built-in variables are global, meaning they are visible anywhere in Tasker (e.g. %WIFI)
User variables which have one or more capital letters in their name are also global (e.g. %Car)
However, user variables which have all-lower-case names (e.g. %fruit) are local, meaning they are only visible in the task in which they are used (or the scene in which they are used, if the task was launched from by a scene event).
In general, it's best to use local variables wherever possible because:
you know they won't be interfered with by other tasks
they are more efficient in several ways
Note: multiple copies of the same task running at the same time each have their own separate copy of their local variables.
Tasker for Android
Code:
Thanks for the info. I'll keep that in mind for future reference, however...
In my original post/example I should have used what I actually had in Tasker which is:
1. if %powerAmpOn=False
2. Security Setting - Configuration Set Pin
3. endif
The above would not work however the following did
1. if %powerAmpOn ~ False
So... Did the last example work because I changed the = to ~ or because I removed the endif???
According to the User Guide section on pattern matching
"Matches (~)
The right parameter is a pattern which the left parameter is matched against.
Equals (=)
As above, but the two parameters must be numerically equal."
If I interpret that correctly, you fixed it by replacing the operator used to compare numeric values (=) with the one that is to compare strings (~). Got bit by that myself the other day! :D
-IAmHe
