Tasks, are they Events in Andriod?
bhavbhuti
Hi all
Just today I became a proud owner of HTC Incredible S.
For recurring tasks on SunBird / Lightning I used Tasks to sync with my previous HTC Touch. On the phone I used to delete the completed task (not it's recurrence) as and when completed. Till then it used to show me as Overdue.
Now being new on HTC Incredible S and Android I am sure I missed something. My recurring tasks (esp. weekly ones) show up on the calendar (I am fine with that) but the completed ones I cannot delete, it deletes the full recurrence. And the overdue ones no longer appear in the widget. I hope to use MyPhoneExplorer to sync with SunBird / Lightning.
Please advise
Thanks and regards
Bhavbhuti
They're connected. You can just ignore the previous if done. However I use Astrid to manage my tasks which works better. Once you mark a task as done, the recurrence is untouched.
Thanks Chanchan05. I found out that the recurrance was not set in SunBird due to the fact that FinchSync (to sync with my previous WM6 phone) was not able to handle recurrance. I can now properly set recurrance in SunBird and never a bother.
Though there is one problem, if the Task, though recurring, is deleted from the MPE Task widget, all the recurrance gets deleted from SunBird. So the deletions have to be done from SB and not MPE.
Thanks and regards
Bhavbhuti
