Teardown guide
***I AM NOT RESPONSIBLE IF YOU BREAK YOUR PHONE***
#1 Remove sim/sd card slot and you will see a space between the back cover and the sim slot, use a plastic pry tool or a fingernail, and go around the phone undoing the clips slowly, there is glue at bottom and top of the cover (does not restick after removing)
http://i.imgur.com/rn5skdj.jpg
#2 This is where you should be at this point, fingerprint ribbon is held down by a plastic cover, but you have to remove the retention metal thing around the camera to remove the fingerprint cable
http://i.imgur.com/MDIn20z.jpg
#3 This is as far as i went, i removed all the screws and that seemed to release the screen a bit, but there is glue holding it and i dont want to go that far
http://i.imgur.com/AmwdV2Z.jpg
It seems to replace anything but the fingerprint and camera lense you will have to remove the display as the plastic is all one piece
I dont know where to get replacement parts or anything, looked up a few of the numbers on parts and got no results
Good job.
It would probably be cheaper to get a whole new Zmax Pro than to try to find the parts online.
  • Like
Reactions: lvt
