Help Tec tile issues?
TeamPEZ
Hi friends,
SonI got a bunch of these Tec Tile dooflickies and I'm just not having any luck setting them the way I want or why i bought them in the first place. Maybe someone can help?
Problem 1. I'd like my Bluetooth to kick in when I place the my G3 in the phone holster and when I remove it from the holster, it shuts off. Is this possible?
Problem 2. I'd like to be able to mute my email and text sounds (but keep cell phone active) at night when my wife and I lay down - usually about 10. When I remove it, it will become active again. Is this possible?
I know I can write multiple options with these tiles, but I can't find one to unlock the home screen.
If anyone of you can help, I would name my next child after you :)
TIA,
-TP
Positioning of the tile can be key, depending how picky you are.
There are various apps you can use to make the most out of NFC stickers. It sounds like you just need a toggle for bluetooth on one sticker.
For your email, if it's set up as an exchange account you can set peak/off peak settings for checking frequency (so it just won't check at night) but this option is not available if set up as pop3 account. But to have the same apply to SMS you'd be better off trying an alternative app like gosms. (very customisable)
Things like unlocking the home screen need root access. FYI there is a way to make nfc detect tags evan with the screen off and inactive.
