tech help with galaxy note
stuartavo
Can anyone help on a few issues.
screen turns off whilst using the tablet.i have to swipe the home screen and I can then carry on as normal. Where can I find settings for this?
When I shut the tablet down I sometimes get a different off screen.this will not turn the tablet off.i have to press the off button repeatedly un til I get the right sc reen.this then shuts down normally.whats wrong is it a software glitch?
thanks to all the techies
Sorry I can't help. But I can offer a suggestion:
A lot of people can't/won't help unless they know what you're talking about. I had to read and reread your post 3-4 times just to understand it. Spelling/grammatical errors aside, I still don't know what you're describing. Perhaps describing things a bit better would garner more help.
Just sayin'
I have 2 things to correct.
1 in normal use and even when I am typing the screen will revert back to the home screen.i have seen it time out every 20 seconds and then nothing for ten minutes
2.when I go to turn the tablet off with the top left button sometimes I get a different off screen come up.this will not allow me to shut the tablet down.however if I press the top left button repeatedly I get the correct shut down screen and I can the shut the tablet down properly.
OK. First off, are you using a cover? What kind of cover is it? Now you may think, "What does the cover have to do with anything".
Well when I first bought mine, the previous owner included a Samsung Cover. I thought it was the orginal. It started doing some really weird things: Can't swipe down, can't reboot, different menus, etc.
I discovered that the cover had magnets in the wrong places that did some funky things with this tablet. Removed the cover, and everything was fixed. Have had no problems since.
