hallstevenson
Android Expert
Anyone use "Temp Monitor Lite" ? Anyone compare it's readings to those from *#*#4636#*#* ?
Currently, mine indicates 29C in the status bar. It polls the temperature every 15s as I recall. I've checked the temperature by "dialing" the above code, selecting "Battery info" and it can be different by 5 degrees or more.
As I recall, the Wireless Tether app's number agrees with the "Battery info" number (I suspect it queries that value).
