Temperatures and battery drain
brian1984
I ve been checking my phone with new 1900 battery...
and its strange that during 8 hours at work, my phone was in standby (just turning screen on to check if i got messages which i didnt have or maybe just 2..) battery was lossing power faster than at home while using the phone....
i think the only diference besides that at home i was almost static all the time and at work moving arround.. is that the battery was a 30 C most of the time
and at work 37C 38C..
is the temperature a big difference or maybe its just an accuracy problem between battery levels and phone???
ill try to upload a picture..
the last part where the line look 'more even' is when i was at home... temps were around 30C to 32C
all before that was more than 35 and less than 40 when i was able to check...
also display was on for total time of 1 hour 15 minutes
and battery left said 12% when i took last pic.
and other thing is that oday i tried wifi all day long, usually i use wifi only at home but since i hear that wifi should be better than having 4g i was testing this and for it is the same result at the end...
Was your phone looking for a wifi signal while at work? What's that icon on the top left in your menu? I froze almost all my metro apps right away so I really have no idea what it is. Anyway, if it was looking for a signal (which I'm guessing it was by looking at your drains - wifi was #2) that would drain your phone faster. I've started using airplane mode a lot while at work.
