ronaldramsayii
While we all work on a full root solution for the G2, temproot is very useful, but a bit of a faff. Enter VISIONary.
VISIONary (so named since we're playing with the HTC Vision here right? ) is an application you install on your device which gives you an icon in your launcher.
Handy eh?
There is another little nicety in there too, in that when the root is finished, VISIONary launches /data/local/visionary.sh (if it exists), so if you have any stuff you want to happen every time you root, put it in there!
The application is now ONLY available from the Android Market. Note that the new release allows you to toggle whether on not the application runs on startup!
USB DEBUGGING MUST BE ENABLED FOR VISIONARY TO WORK!
Enjoy!!!
Thanks to paulobrien over at XDA-Devs
- Click the icon (or have it run on boot!)
- Vuala....Rooted!!!
Handy eh?
Enjoy!!!
