Testing
  • Thread starter Thread starter Member2047631
  • Start date Start date
Testing
1) liked no flash
2) liked flash
3) liked flash
4) liked no flash but that cabinet was blurry, maybe the angle?
5) liked flash
What do you conclude from this Dr. Puggers?
6) liked flash.
Off topic: Did you have to manually save each picture? I started a topic about that in the Android Lounge.
They didn't use the flash, they used HDR and no HDR, the non-HDR ones were darker and pretty much overall worse. I move all my pictures to my SD card in a specific folder depending on what the image is of.
And I don't have flash or a flashlight on my tablet, so 😛
And I kind of mixed it up, instead of consistently putting HDR on the top and non on the bottom, I accidentally mixed it up a few times, although you can probably tell which one is which.
(if you couldn't tell, I like HDR, except for that it lags a lot after you take a picture, and you can't hold down the camera button to take multiple pictures and make an animation, and I don't think you can even take HDR video, because I tried it with and without and they looked the same.)
So you don't even have to upload it, you can just open the image in a new tab, then copy the link and just add the IMGs to the beginning and end! Yay! 😀
