Tether by wire
Blizzard
Since I cannot get FoxFi to work on my Nexus 7, can I tether to my phone by wire with Easy Tether. If so, what kind of cable is needed?
You don't say what phone you have - the app runs on the phone, not the Nexus 7 - but I had a lot of problems getting FoxFi to work reliably on my "old" Motorola Milestone. Indeed nothing worked (tried lots of apps) until I tried a free app called "3G Mobile Hotspot" which worked perfectly. It runs a proper infrastructure hotspot with optional (essential!) encryption and it works fine with the Nexus 7... or pretty much any computer/device that has wi-fi.
Much better than wires :-)
I tried it with FoxFi on my phone and PDANet on my Nexus.
I keep getting the following message:
Fail to connect Bluetooth server
(err=23)(java.io.IOException: read failed, socket might closed, read ret: -1)
I had that error before, let me hunt around for a fix
I know this is an old thread, but I'm having the same issue. I am running foxfi with bluetooth server mode on, and PDAnet on a Nexus 7.
I get the error-
Has any progress been made on this?
I restarted the tablet and it worked!
I get the error-
