HasH_BrowN
Android Expert
This method requires root!
*As always make a backup. I will not be held responsible for any damages you do to your device*
These steps will let your device enable WiFi Hotspot. The app Shorcut Master from the Play Store is the only app needed, as everything else is done on the device.
https://play.google.com/store/apps/details?id=org.vndnguyen.shortcutmaster.lite
*I was able to use WiFi hotspot without any build.prop edits. I am a Virgin Mobile customer, but this should work for all carriers*
- Open Shortcut Master
- Open the 3 dot menu (upper right corner), select Search (third option)
- Type APN, then tap SEARCH
- Scroll to and select com.lge.hiddenmenu, it says underneath it in Grey lettering com.lge.hiddenmenu.vzw_only.apnsettings
- Select Launch (the red rocket icon)
- Select Internet
- Scroll down to APN type
You will see default, mms, - Add dun to the end. So it reads "default,mms,dun" exactly
- Open up 3 dot menu and select Save
- Reboot
- Open WiFi hotspot settings, configure a SSID and a secure password (absolute necessity)
- Final step, ENJOY
