HasH_BrowN
Android Expert
I can go back later and dig through logs to see what was the root cause of the problem. I had rebooted probably 20 times throughout the day changing settings and doing other fixes. Every time I would select the ..apnsettings, it would pop up and show an error that was long enough to cover the majority of the screen. It referenced multiple services not running or responding. I did a quick google and a few hits referenced ADB issues. I kept getting errors from Greenify stating that it couldn't hibernate several apps, so I read a little bit and realized that I needed X-posed framework installed to get the rest of the apps to sleep. I dl'd it, installed, rebooted, checked that Greenify worked, jumped back to Shortcut Master and it works all of a sudden. First thought is that X-posed, which was the only thing that had changed, was what fixed it.
By @modhatter6811
I think it does have something to do with xposed. I was getting the same error message since the zv6 update. I tried manually wiping cache and dalvik after installing the app, and still got the error 2. Tried installing xposed, worked instantly. This makes me think something in the app is either dependant on xposed, or that installing xposed cleans up some file we're not aware of. They don't state you need xposed though, so I'm thinking the latter.
Did you try without installing greenify? The way greenify works, might be the cause of the error. While greenify is installed, Xposed straightens out?.?.?.
If it does turn out that is the issue, please go to the support site for greenify and leave whatever type of feedback that the dev needs. See if this issue can be resolved.
I had issues with Xposed modules working on a Walmart version (wife's) after the zv6 update, still testing. But the phone worked perfectly fine with or without the framework installed. That's why I think its not Xposed, but a module. In this case greenify.
BTW you can control wakelocks better and easier with MyAndroidTools by Wanqi, plus you can shutdown different services and activities for each app. Also so easy to use and run.
. Got 20 hours of things todo in 3.5 hours.
