My girlfriend and I are going away this weekend, and there is no wireless access anywhere. Are there any applications (I've got an HTC Hero running Gingerbread) that I can install that will allow us both to connect at the same time?
The built-in Hotspot feature (see Settings) turns your phone into a wireless mobile WiFi hotspot to which any number of computers (well, at least a handful, afaik) can be linked.
Of course the data connection will be over 3G, GPRS, or CDMA (or even 2G if you're unlucky) so it will be eating into your data plan. If you have an 'unlimited data plan' be aware that it is probably subject to a 'fair use policy', which of course means it is not 'unlimited' at all! And I can tell you from experience that you exceed those limits a lot sooner that you expect! And that's waaay expensive.
If you are rooted, download Wifi Tether. The stock wifi tethering ability might not work unless you are on a custom rom.
Try Barnicale,it works for my comp and my girlfreinds Ipod at the same time
