suprafreak
I found settings on the wifi tether app that works great for me with no errors.
Device profile: generic ics/jb wlan0
settup: soft tap for samsung (master)
set up your prefered ssid and encryption.
wifi driver reloading: options 1and 2
EDIT: make sure mss clamping and routing fix is enabled
the rest i didnt mess with
i got fast 3g speeds. i havent tested on 4g tho
last 2 hours i was watching netflix
after i hit my data cap.. im gonna try to see if theres a way to go around the throttle like i did with my sequent.
EDIT: sometimes samsung soft tap doesnt work, when that happens try netd-ndc(master) instead.
soft tap was working for me yesterday but now i get errors im not sure why.
