Help tether without USB
Hi
It depends what you are trying to do, but have a look at Airdroid on Playstore. There are simpler apps if you only want file transfer - search Playstore for "ftp transfer"
Personaly I use Dropbox and Drive for sharig files between devices
If you are trying to share your phone's internet connection with your PC, you'll need to enable the WiFi hotspot feature on your phone. If it;s not there or won't connect, it's probably because your carrier requires a special plan to do that.
