hey there,
i would like to know how many devices can I tether to my droid? i downloaded a couple of apps to test it (like: easy wifi) to spread by dataplan to my devices at home and it works well, but...can this also be done for larger crowds?
I have a small event coming up and instead of relying on the hotels' daily expensive internet access, I wanted to get a couple of the lower end samsungs with a pre-paid data card and simply spread/tether wifi to the event participants.
which min. android version do you generally recommend in order to achieve MAX. tethering of devices? any good/bad experiences you can share? what should I look out for?
thanks.
thanks.
