Help Tethering - Mobile data link lost
As soon as I turn on tethering and connect, I instantly get "Tethering: Mobile data link lost"?
This is the same for both wireless and USB connecting to my Motorola RAZR i.
Any suggestions welcome, as I've a train journey tomorrow where I was hoping to tether and work...
Hey there WannabeMKII,
I have moved your thread into the RAZR i forums in hopes that you can get some quick support. Hope this helps! :)
No problem Digital Controller.
I've managed to fix the issue. I needed to add ",dun" to the Access Point Names under APN Type and now working perfectly!
Like others, Mobile Link worked initially but then stopped working and giving me a "no connection" message on my MV900F Samsung camera and terminating the WIFI connection with my Galaxy S4.
I found an easy way to fix this through trial and error.
On my Galaxy S4 I went into the Application menu, navigated to the Mobile Link program and selected it and the "Settings" menu came up. I went to "Cache" and emptied it and it works perfectly now.
Called Samsung customer support with this fix as they did not know - :)
Works perfectly now and I love this feature.
