themalakas
Hi All
I am new to the forums, and I am looking to find out if there is out there ANY android text/code editor that supports text folding (this means to be able to expand/collapse section of the code by pressing a button so it makes it much more readable)
I have spent so many hours researching on the internet and downloading/testing android apps but NONE supports this function which sounds very very weird!
I am using an S2 and soon upgrading to Note 2.
I would really appreciate your help as this is really important for me!
Thank you,
Chris
Thank you,
Chris
