only way i have managed to fwd a sms is to 'copy all text' by long pressing on the msg, then send to whoever by pasteing into a new message.
as for settings, not done this my self, but id say the networks website is the place to sort that.
If you just long press on the message it should give you a pop up and the first option is forward. Select this and it opens up a new message with that text in already you just need to select your new contact to send it to.
