Help Text message coding help!!
  • Thread starter Thread starter Xxxxx ttttttt
  • Start date Start date
X
Xxxxx ttttttt
Guest
So I transfered saved text messages from my Samsung Galaxy 6 to my computer running on Vista. I tried opening them and I have NO IDEA what program to use or what to do to view them correctly. They are all coded. If anyone out there could help me, I would be so grateful. Thanks in advance for looking and possibly helping. :):thumbsupdroid:
What did you use to backup? you will need to use the same app to restore. Unfortunately it is not as simple as just copying and pasting text files, AFAIK there is no way to do that.
really it is not? so it is not like copying and pasting a picturing? because that works? it looks like all stuff is there? I didnt use an app? So I am confused then I still have more? What exactly is the proper technique?
No, as far as I know there is no way to restore like that. If you search sms backup in play store there will be several apps that will backup and restore but I doubt you will be able to restore from how you have done it now :( may be wrong but not as far as I know.
okay thanks for your help, I appreciate it! I guess I should have asked first before doing so. I just thought it was that simple. Hopefully more people do come along and can help me out.. The messages are broken down into KB. I got the picture messages like I said. If I cant retrieve them okay. :( I would just like to know for certain. And for the future how to do it right, if someone could help me with that at least.
