Help Text Message Sound
  • Start date Start date
A
Android Question
Guest
The text message sound isn't working on my S5. I have made sure all volume is turned up and on
What happens if you change the message sound? And maybe check your "do not disturb" settings. Do you get a notification at all (pop up or in notification bar)?
