Help text messages failing
Every afternoon I seem to have the same problem with texts, this being they fail, does anyone else have this problem with this phone as it is seriously driving me mental. If you did have it how did you fix it is it a handset problem, o2 have told me it could be an issue with my Sim but it only happens in the afternoon so I think this is a fob off. Please help me
I send approximately 60 text messages a day, and I don't have any problems.
If that happens only in the afternoon, or after afternoon, then I don't think it is related to your phone, it might be related to your sim really, and maybe your signal quality?
May I suggest that you check your signal strength when you can send texts and when you can't send them. I cannot believe that a phone problem would be time dependant, but I have experienced mobile signals being overloaded at busy times.
Afternoons are normally when most texts are sent.
Are usually in a different place in the afternoon?
Have you downloaded something from Market which alters the way texts are sent or a different Messaging app?
